XCR1250 Posted September 12, 2017 Share Posted September 12, 2017 http://i.imgur.com/W6L1yMp.gifv 1 Quote Link to comment Share on other sites More sharing options...
Platinum Contributing Member Skidooski Posted September 12, 2017 Platinum Contributing Member Share Posted September 12, 2017 HOLY SHIT!!!!! Quote Link to comment Share on other sites More sharing options...
Gold Member Kivalo Posted September 12, 2017 Gold Member Share Posted September 12, 2017 That was nuts! Quote Link to comment Share on other sites More sharing options...
Sleepr2 Posted September 12, 2017 Share Posted September 12, 2017 He must have accidentally hit the flush handle Quote Link to comment Share on other sites More sharing options...
snoughnut Posted September 12, 2017 Share Posted September 12, 2017 That looked very expensive. Quote Link to comment Share on other sites More sharing options...
AKIQPilot Posted September 12, 2017 Share Posted September 12, 2017 Wow. The cylinder head was completely gone and all the liners were pushed right out of the block. I hope no one was hurt by that cyl head that probably went 500' in the air. Quote Link to comment Share on other sites More sharing options...
Dave Posted September 12, 2017 Share Posted September 12, 2017 Keep on truckin.... Quote Link to comment Share on other sites More sharing options...
Cold War Posted September 12, 2017 Share Posted September 12, 2017 Whoa! Quote Link to comment Share on other sites More sharing options...
SmeeAgain Posted September 12, 2017 Share Posted September 12, 2017 Damn! There should be some prize for the best equipment failure at those events. Quote Link to comment Share on other sites More sharing options...
Carlos Danger Posted September 12, 2017 Share Posted September 12, 2017 37 minutes ago, AKIQPilot said: Wow. The cylinder head was completely gone and all the liners were pushed right out of the block. I hope no one was hurt by that cyl head that probably went 500' in the air. No the cylinder head was still on. What happens when those straight engines let go like that is they break the block right above the crank shaft which gives you 75% of the engine going out the hood. You can see the bottom of the bores at the end of the video. Quote Link to comment Share on other sites More sharing options...
AKIQPilot Posted September 12, 2017 Share Posted September 12, 2017 2 minutes ago, Carlos Danger said: No the cylinder head was still on. What happens when those straight engines let go like that is they break the block right above the crank shaft which gives you 75% of the engine going out the hood. You can see the bottom of the bores at the end of the video. Yea I thought that may be the case. I looked at it again and stop framed it. You are exactly right. The crank, rods and pistons are still sitting in the chassis hooked to the transmission. That was some violent shit right there. Quote Link to comment Share on other sites More sharing options...
Momorider Posted September 12, 2017 Share Posted September 12, 2017 4 minutes ago, AKIQPilot said: Yea I thought that may be the case. I looked at it again and stop framed it. You are exactly right. The crank, rods and pistons are still sitting in the chassis hooked to the transmission. That was some violent shit right there. Yah think????? Quote Link to comment Share on other sites More sharing options...
AKIQPilot Posted September 12, 2017 Share Posted September 12, 2017 Just now, Momorider said: Yah think????? I thought you were on vacation from this place for a while. It sure was nice not having you around............ Quote Link to comment Share on other sites More sharing options...
Momorider Posted September 12, 2017 Share Posted September 12, 2017 5 minutes ago, AKIQPilot said: I thought you were on vacation from this place for a while. It sure was nice not having you around............ Quote Link to comment Share on other sites More sharing options...
Kev144 Posted September 12, 2017 Share Posted September 12, 2017 7 minutes ago, AKIQPilot said: I thought you were on vacation from this place for a while. It sure was nice not having you around............ Vacation? Must have went to Thailand to taste the local cuisine Quote Link to comment Share on other sites More sharing options...
AKIQPilot Posted September 12, 2017 Share Posted September 12, 2017 Just now, Kev144 said: Vacation? Must have went to Thailand to taste the local cuisine It's pretty incredible for sure. And dirt cheap for what you get. Quote Link to comment Share on other sites More sharing options...
Momorider Posted September 12, 2017 Share Posted September 12, 2017 1 minute ago, Kev144 said: Vacation? Must have went to Thailand to taste the local cuisine Is that were you sodomizing homosexuals go Faggot? Quote Link to comment Share on other sites More sharing options...
Platinum Contributing Member Highmark Posted September 12, 2017 Platinum Contributing Member Share Posted September 12, 2017 That's fucking wild. Cool post. Quote Link to comment Share on other sites More sharing options...
Kev144 Posted September 12, 2017 Share Posted September 12, 2017 1 minute ago, Momorider said: Is that were you sodomizing homosexuals go Faggot? How was it this time? Quote Link to comment Share on other sites More sharing options...
Carlos Danger Posted September 12, 2017 Share Posted September 12, 2017 1 hour ago, AKIQPilot said: Yea I thought that may be the case. I looked at it again and stop framed it. You are exactly right. The crank, rods and pistons are still sitting in the chassis hooked to the transmission. That was some violent shit right there. The irony is once these guys get up near 100 psi of boost they stumble into jet engine math. What they end up with is a weak jet engine for the amount of fuel and a fragile power turbine (ie the Pistons and block). They could just get an old turbine Allison off of a C130 and it would make that kind of power stock. Quote Link to comment Share on other sites More sharing options...
1jkw Posted September 12, 2017 Share Posted September 12, 2017 Did Ben build that engine? Quote Link to comment Share on other sites More sharing options...
racinfarmer Posted September 12, 2017 Share Posted September 12, 2017 8 hours ago, snoughnut said: That looked very expensive. $75,000+. A guy I know did something similar to his pulling tractor and said it was going to be a minimum of $80k to get another engine, not including all the other shit he wrecked. Quote Link to comment Share on other sites More sharing options...
AKIQPilot Posted September 12, 2017 Share Posted September 12, 2017 52 minutes ago, racinfarmer said: $75,000+. A guy I know did something similar to his pulling tractor and said it was going to be a minimum of $80k to get another engine, not including all the other shit he wrecked. Thats a lot of coin just to turn hydrocarbons into noise. Quote Link to comment Share on other sites More sharing options...
ActionfigureJoe Posted September 13, 2017 Share Posted September 13, 2017 8 hours ago, Momorider said: shit eater Quote Link to comment Share on other sites More sharing options...
racinfarmer Posted September 13, 2017 Share Posted September 13, 2017 1 hour ago, AKIQPilot said: Thats a lot of coin just to turn hydrocarbons into noise. Makes dirt cars and sleds seem pretty reasonable! Quote Link to comment Share on other sites More sharing options...
