- Replies 21
- Views 1.2k
- Created
- Last Reply
Kivalo 5 posts
Frostynuts 3 posts
Carlos Danger 2 posts
Whiskey Tango Foxtrot 2 posts
Would dropping it off the trailer give it a jolt and bring it back to life ? LOL Where is Ben the boat mechanic when he is needed ?
He's never going to shake that mistake. I'm in the same boat after sinking a measly drone.
The funny part is there are only some very minor scratches in the hull near the transome, barely more than surface scratches. I bet your drone incedent was more expensive! Plus I blamed it all on my b
RPM drop between 2300-2400 while under acceleration. The boat climbs from idle and once it hits 23-2400 rpm is dropps approximately 150-200 rpms and runs rough. If there was enough throttle applied it will climb past but if I leave it at that rpm level it will continue to run rough. Same thing happens at 2900-3000rpm. Then when back at the dock I shut down the engine and restarted it and I had to give it some throttle to get it to start at that point it seemed to idle properly. Its a fuel injected engine which shouldnt need throttle in start up? Right?
Any ideas?
