Fireball 440 Posted May 21, 2017 Share Posted May 21, 2017 I recently helped an old man out and cleaned out his yard. I now own 4 old Ford trucks and a Western snow plow. Heres what I have:1988 Bronco 302 w/AOD, 1991 F-150 351 w/E4OD, 1989 F-150 302 4 spd, 1989 F-150 5 spd. All are 4x4. Only the Bronco ran and moved, this is the engine from it. It actually ran really quiet and smooth, but found a mess inside. Quote Link to comment Share on other sites More sharing options...
Fireball 440 Posted May 21, 2017 Author Share Posted May 21, 2017 It was leaking everywhere so I took it apart. No shortage of stop-leak here! Also looks like its missed a few oil changes! Quote Link to comment Share on other sites More sharing options...
Fireball 440 Posted May 21, 2017 Author Share Posted May 21, 2017 Quote Link to comment Share on other sites More sharing options...
Fireball 440 Posted May 21, 2017 Author Share Posted May 21, 2017 So.... I can rebuild anything but, what say you all about all this stop-leak crudding up everything? worth the effort or should I crack open the next one before ordering gaskets and such? Quote Link to comment Share on other sites More sharing options...
Mileage Psycho Posted May 21, 2017 Share Posted May 21, 2017 (edited) That engine looks like a lot of work and money. Edited May 21, 2017 by Mileage Psycho Quote Link to comment Share on other sites More sharing options...
Rod Posted May 21, 2017 Share Posted May 21, 2017 Those things are scrap Quote Link to comment Share on other sites More sharing options...
Fireball 440 Posted May 21, 2017 Author Share Posted May 21, 2017 Lot of work yes, money no. I have 2 more of them that don't run, and a blown up 351. Full gasket set is only $50. I also kept the radiator and starter from the Bronco, then shipped it to the junk yard. The trans was shot and the body mounts were rotted out. I sold the tailgate on CL for 50 bucks lol. Quote Link to comment Share on other sites More sharing options...
Fireball 440 Posted May 21, 2017 Author Share Posted May 21, 2017 OK so I think I'll just let this engine sit here on hold until I get the other 2 trucks back here to my place to comb over. I also have this one with a well overheated 351 that wont rotate. Quote Link to comment Share on other sites More sharing options...
racinfarmer Posted May 21, 2017 Share Posted May 21, 2017 You could pull the oil pan off, drag it into the local wash bay and pressure wash the hell out of it and see what you end up with. I'd also bring a bunch of WD-40 with the spray it down asap if you decide to keep it. Quote Link to comment Share on other sites More sharing options...
Carlos Danger Posted May 21, 2017 Share Posted May 21, 2017 1 hour ago, Fireball 440 said: Lot of work yes, money no. I have 2 more of them that don't run, and a blown up 351. Full gasket set is only $50. I also kept the radiator and starter from the Bronco, then shipped it to the junk yard. The trans was shot and the body mounts were rotted out. I sold the tailgate on CL for 50 bucks lol. I would strip it down and send the heads and block out to get cleaned/boiled. Then look the block over and depending on wear get it bored. Quote Link to comment Share on other sites More sharing options...
ActionfigureJoe Posted May 21, 2017 Share Posted May 21, 2017 2 minutes ago, Carlos Danger said: I would strip it down and send the heads and block out to get cleaned/boiled. Then look the block over and depending on wear get it bored. ditto. Quote Link to comment Share on other sites More sharing options...
Cold War Posted May 21, 2017 Share Posted May 21, 2017 Not sure what you want out of it? Performance or stock rebuild, but the heads are junk. I would invest in performer heads, cam, intake kit. Bottom ends are bullet proof. 302 are a dime a dozen. Probably pick up a low mile one , ready to go , for next to nothing. Quote Link to comment Share on other sites More sharing options...
Fireball 440 Posted May 21, 2017 Author Share Posted May 21, 2017 Whoaaaa!!!! Let's not get carried away with spending money here fellas! No machine shop shit here this is a budget build! End Goal is just a reliable truck to plow out my cabin, haul firewood, and drive forest roads in the summer, and maybe a second runner to sell off, and keep one parts truck. 1 Quote Link to comment Share on other sites More sharing options...
ActionfigureJoe Posted May 21, 2017 Share Posted May 21, 2017 3 minutes ago, Fireball 440 said: Whoaaaa!!!! Let's not get carried away with spending money here fellas! No machine shop shit here this is a budget build! End Goal is just a reliable truck to plow out my cabin, haul firewood, and drive forest roads in the summer, and maybe a second runner to sell off, and keep one parts truck. i misread your initial post. i thought it said "my old man". i figured the truck had some sentimental value to you. having clarified that....scrap the pieces of shit. Quote Link to comment Share on other sites More sharing options...
Cold War Posted May 21, 2017 Share Posted May 21, 2017 Lol, oh. I would gunk the heads, clean out the ports, new gaskets, water pump, and run it. Quote Link to comment Share on other sites More sharing options...
Fireball 440 Posted May 21, 2017 Author Share Posted May 21, 2017 I can clean those valves up and put new seals in them for basically free. The Ford valve spring tool is only $12. I'll reserve further decision making until after I pop off the main and rod caps, but the bottom end should be fine. Quote Link to comment Share on other sites More sharing options...
Carlos Danger Posted May 21, 2017 Share Posted May 21, 2017 43 minutes ago, Fireball 440 said: Whoaaaa!!!! Let's not get carried away with spending money here fellas! No machine shop shit here this is a budget build! End Goal is just a reliable truck to plow out my cabin, haul firewood, and drive forest roads in the summer, and maybe a second runner to sell off, and keep one parts truck. I understand but sometimes you just make more work for yourself by cutting corners. I think I was paying $50 to get a block cleaned. Quote Link to comment Share on other sites More sharing options...
Fireball 440 Posted May 21, 2017 Author Share Posted May 21, 2017 I hear ya. If not anything else I'll keep one of these to make carb and do the heads, cam, headers, etc all the common old ford stuff. Quote Link to comment Share on other sites More sharing options...
Fireball 440 Posted May 29, 2017 Author Share Posted May 29, 2017 (edited) Ok keeping this one for carb build and already planning it out. Spent 3 hours cleaning 30 years of baked on sludge today. Edited May 29, 2017 by Fireball 440 3 Quote Link to comment Share on other sites More sharing options...
Momorider Posted May 29, 2017 Share Posted May 29, 2017 On May 21, 2017 at 3:20 PM, Fireball 440 said: Lot of work yes, money no. I have 2 more of them that don't run, and a blown up 351. Full gasket set is only $50. I also kept the radiator and starter from the Bronco, then shipped it to the junk yard. The trans was shot and the body mounts were rotted out. I sold the tailgate on CL for 50 bucks lol. Go dump it in the lobby of the Canadian border agency Quote Link to comment Share on other sites More sharing options...
old indy Posted May 29, 2017 Share Posted May 29, 2017 I think id be more apt to rebuild the 351 over any 302 of that era. but i understand having the three to combine too.. Quote Link to comment Share on other sites More sharing options...
f7ben Posted May 29, 2017 Share Posted May 29, 2017 I'd just run it ....new chevy 5.3's look worse than that after 25k miles of cylinder deactivation Quote Link to comment Share on other sites More sharing options...
AKIQPilot Posted May 29, 2017 Share Posted May 29, 2017 4 minutes ago, f7ben said: I'd just run it ....new chevy 5.3's look worse than that after 25k miles of cylinder deactivation Link? Quote Link to comment Share on other sites More sharing options...
f7ben Posted May 29, 2017 Share Posted May 29, 2017 3 minutes ago, AKIQPilot said: Link? http://www.latlmes.com/world/chevy-issues-53-recall-due-to-premature-cylinder-failure-1 Quote Link to comment Share on other sites More sharing options...
