spin_dry Posted June 1, 2019 Share Posted June 1, 2019 Anyone gone through the task of replacing one? Son in law has a tractor with a fracture gear. I’m considering taking the motor out and home with me to rework. Quote Link to comment Share on other sites More sharing options...
racinfarmer Posted June 1, 2019 Share Posted June 1, 2019 Looks like there might be a Youtube video on it, maybe a few? Probably isn't any more difficult then any other 4 smoker motor. I'd take it home and clean it up good on the workbench while I was at it. Quote Link to comment Share on other sites More sharing options...
spin_dry Posted June 1, 2019 Author Share Posted June 1, 2019 9 minutes ago, racinfarmer said: Looks like there might be a Youtube video on it, maybe a few? Probably isn't any more difficult then any other 4 smoker motor. I'd take it home and clean it up good on the workbench while I was at it. It looks like I can pull the front cover with simple removal of the muffler and battery. The unit has 1200 hours. No leaks anywhere and runs good otherwise. Quote Link to comment Share on other sites More sharing options...
Pete Posted June 1, 2019 Share Posted June 1, 2019 56 minutes ago, spin_dry said: Anyone gone through the task of replacing one? Son in law has a tractor with a fracture gear. I’m considering taking the motor out and home with me to rework. Is that a Koehler engine? Quote Link to comment Share on other sites More sharing options...
spin_dry Posted June 1, 2019 Author Share Posted June 1, 2019 1 minute ago, Pete said: Is that a Koehler engine? Kawasaki. I just yanked the motor. It came out in under 30 minutes. Quote Link to comment Share on other sites More sharing options...
Pete Posted June 1, 2019 Share Posted June 1, 2019 1 minute ago, spin_dry said: Kawasaki. I just yanked the motor. It came out in under 30 minutes. Cool I have a kawi in my JD 335GX. It’s been flawless but did a have a problem with it skipping. The rockers had too much lash. Well good luck fixing it. Nice to see you can handle this most can’t Quote Link to comment Share on other sites More sharing options...
DriftBusta Posted June 1, 2019 Share Posted June 1, 2019 1 hour ago, spin_dry said: It looks like I can pull the front cover with simple removal of the muffler and battery. The unit has 1200 hours. No leaks anywhere and runs good otherwise. Thats a nice little tractor. I think its the predecessor to the x730 I have now. Mine has the 25 hp Kawie liquid v twin, i think that 425 has the same motor as that Wheel Horse I used to have. Quality units. Quote Link to comment Share on other sites More sharing options...
spin_dry Posted June 1, 2019 Author Share Posted June 1, 2019 1 hour ago, Pete said: Cool I have a kawi in my JD 335GX. It’s been flawless but did a have a problem with it skipping. The rockers had too much lash. Well good luck fixing it. Nice to see you can handle this most can’t It’s a simple design. I’ll crack it open and install the cam kit and water pump. OEM parts kit is about $350. Includes all the necessary hardware and gaskets. Quote Link to comment Share on other sites More sharing options...
Pete Posted June 1, 2019 Share Posted June 1, 2019 21 minutes ago, spin_dry said: It’s a simple design. I’ll crack it open and install the cam kit and water pump. OEM parts kit is about $350. Includes all the necessary hardware and gaskets. Good on the OEM stuff. Can’t beat it Quote Link to comment Share on other sites More sharing options...
Pete Posted June 1, 2019 Share Posted June 1, 2019 56 minutes ago, DriftBusta said: Thats a nice little tractor. I think its the predecessor to the x730 I have now. Mine has the 25 hp Kawie liquid v twin, i think that 425 has the same motor as that Wheel Horse I used to have. Quality units. If I remember correctly you had JD 345 liquid back many years ago? Quote Link to comment Share on other sites More sharing options...
01mxz800 Posted June 1, 2019 Share Posted June 1, 2019 3 hours ago, spin_dry said: Anyone gone through the task of replacing one? Son in law has a tractor with a fracture gear. I’m considering taking the motor out and home with me to rework. go with the steel gear replacement kit includes new valve stronger springs, plastic gear uses lighter springs, spend the money worth it...….did mine with motor in tractor 2 Quote Link to comment Share on other sites More sharing options...
DriftBusta Posted June 1, 2019 Share Posted June 1, 2019 1 hour ago, Pete said: If I remember correctly you had JD 345 liquid back many years ago? Wheel Horse 520lxi. Had the 617cc 20 hp liquid v twin Kawie Quote Link to comment Share on other sites More sharing options...
spin_dry Posted June 1, 2019 Author Share Posted June 1, 2019 (edited) 4 hours ago, 01mxz800 said: go with the steel gear replacement kit includes new valve stronger springs, plastic gear uses lighter springs, spend the money worth it...….did mine with motor in tractor Thanks. Looks like the entire kit is about $300. I’ll replace the water pump while in in there. It’s only $50. The kids should be able to get a lot more use out of the tractor after the new cam kit. Everything else on the tractor is in good shape. It’s worth it. Edited June 1, 2019 by spin_dry 1 Quote Link to comment Share on other sites More sharing options...
01mxz800 Posted June 2, 2019 Share Posted June 2, 2019 11 hours ago, spin_dry said: Thanks. Looks like the entire kit is about $300. I’ll replace the water pump while in in there. It’s only $50. The kids should be able to get a lot more use out of the tractor after the new cam kit. Everything else on the tractor is in good shape. It’s worth it. I've had 2 of those motors apart, the 1 in my old Mule is basically the same and had to put new gaskets in that Quote Link to comment Share on other sites More sharing options...
Platinum Contributing Member Rigid1 Posted June 2, 2019 Platinum Contributing Member Share Posted June 2, 2019 17 hours ago, spin_dry said: It’s a simple design. I’ll crack it open and install the cam kit and water pump. OEM parts kit is about $350. Includes all the necessary hardware and gaskets. This is why you don't buy a Deere. Quote Link to comment Share on other sites More sharing options...
ckf Posted June 2, 2019 Share Posted June 2, 2019 6 minutes ago, Rigid1 said: This is why you don't buy a Deere. what would it retail for regularly for that motor? Quote Link to comment Share on other sites More sharing options...
Platinum Contributing Member Rigid1 Posted June 2, 2019 Platinum Contributing Member Share Posted June 2, 2019 Just now, ckf said: what would it retail for regularly for that motor? I just did a cam on a 37hp big block Kawi. Retail on the cam was $189, my cost was $112. Wore the lobe right off the cam.. The guy always surges his engine, just sticks forward as fast as he can. @spin_dry, make sure you get your torque specs for everything. Quote Link to comment Share on other sites More sharing options...
Platinum Contributing Member Rigid1 Posted June 2, 2019 Platinum Contributing Member Share Posted June 2, 2019 This is what Deere does and why I say don't ever buy one. They go to Kawi, Kohler, Briggs and say we want 25k of this engine, but we want them spec'd to us and a few changes made, in turn the engine mfg will free and clear of all warranties for that engine. Deere will handle all warranties and parts for said engines. They do this so they can double the price in parts.. 1 Quote Link to comment Share on other sites More sharing options...
Platinum Contributing Member Jimmy Snacks Posted June 2, 2019 Platinum Contributing Member Share Posted June 2, 2019 1 minute ago, Rigid1 said: This is what Deere does and why I say don't ever buy one. They go to Kawi, Kohler, Briggs and say we want 25k of this engine, but we want them spec'd to us and a few changes made, in turn the engine mfg will free and clear of all warranties for that engine. Deere will handle all warranties and parts for said engines. They do this so they can double the price in parts.. Damn...no kidding. That's pretty lame. Quote Link to comment Share on other sites More sharing options...
Platinum Contributing Member Rigid1 Posted June 2, 2019 Platinum Contributing Member Share Posted June 2, 2019 Just now, Jimmy Snacks said: Damn...no kidding. That's pretty lame. Extremely, especially when people call you because you're listed as a kohler, kawi, and Briggs distributor and they give you their engine #'s, I log into Kawi or who ever, type in the model and spec, nothing comes up, I ask if it's on. JD, and they say yeah, and I say well sorry you have to go to a JD dealer for that. And then they get all fucking pissed off at me because they bought a piece of shit.. One thing JD does and does well is hide their fucking parts. 1 Quote Link to comment Share on other sites More sharing options...
ckf Posted June 2, 2019 Share Posted June 2, 2019 (edited) 9 minutes ago, Rigid1 said: This is what Deere does and why I say don't ever buy one. They go to Kawi, Kohler, Briggs and say we want 25k of this engine, but we want them spec'd to us and a few changes made, in turn the engine mfg will free and clear of all warranties for that engine. Deere will handle all warranties and parts for said engines. They do this so they can double the price in parts.. That was another major factor in my decision. Plus the Cub Cadet dealer acted like they wanted my business. Rob had told me about this dealer when I was looking for a snow blower a few years back. He told me that they were an excellent dealer to deal with, but that service comes at a price. It costs me $200 more to my door over the JD, but having a dealer that wanted my business was worth it. Edited June 2, 2019 by ckf typo 2 Quote Link to comment Share on other sites More sharing options...
Platinum Contributing Member Rigid1 Posted June 2, 2019 Platinum Contributing Member Share Posted June 2, 2019 1 minute ago, ckf said: That was another major factor in my decision. Plus the Cub Cadet dealer acted like they wanted my business. Rob had told me about this dealer when I was looking for a snow blower a few years back. He told me that they were an excellent dealer to deal with, but that service comes at a price. It costs me $200 more to my do over the JD, but having a dealer that wanted my business was worth it. Exactly, and anything you need for that I can look up in 30 seconds with the #'s. Parts are readily available for it..Was a smart purchase to go with the Cub. Quote Link to comment Share on other sites More sharing options...
ckf Posted June 2, 2019 Share Posted June 2, 2019 1 minute ago, Rigid1 said: Exactly, and anything you need for that I can look up in 30 seconds with the #'s. Parts are readily available for it..Was a smart purchase to go with the Cub. I know I was only looking for a $2000 lawn tractor, but I always tried to treat every customer the same. It didn't matter if they were looking at a $40 paddle, or a $4000 composite boat. I was always taught that the $40 paddle might turn in to that $4000 boat someday if you treat them right 5 Quote Link to comment Share on other sites More sharing options...
Platinum Contributing Member Rigid1 Posted June 2, 2019 Platinum Contributing Member Share Posted June 2, 2019 2 minutes ago, ckf said: I know I was only looking for a $2000 lawn tractor, but I always tried to treat every customer the same. It didn't matter if they were looking at a $40 paddle, or a $4000 composite boat. I was always taught that the $40 paddle might turn in to that $4000 boat someday if you treat them right Truth! Quote Link to comment Share on other sites More sharing options...
jammin Posted June 2, 2019 Share Posted June 2, 2019 17 minutes ago, ckf said: I know I was only looking for a $2000 lawn tractor, but I always tried to treat every customer the same. It didn't matter if they were looking at a $40 paddle, or a $4000 composite boat. I was always taught that the $40 paddle might turn in to that $4000 boat someday if you treat them right Capital BINGO. 1 Quote Link to comment Share on other sites More sharing options...
