Rod Posted March 19, 2022 Share Posted March 19, 2022 60-80 miles range at best is not good enough https://www.caranddriver.com/reviews/a39411899/2022-taiga-nomad-electric-snowmobile-drive/?utm_campaign=socialflowFBCD&utm_medium=social-media&utm_source=facebook&src=socialflowFBCAD&fbclid=IwAR3V4qESUILtDYkofgcTs7xuz7EiMm9OAVhe6mjr242CUmVYKf5D_nKhS2k Quote Link to comment Share on other sites More sharing options...
oldslowsledder Posted March 19, 2022 Share Posted March 19, 2022 Interesting read, thanks. Just can't get my mind around the low range for the price 1 Quote Link to comment Share on other sites More sharing options...
Snake Posted March 19, 2022 Share Posted March 19, 2022 9 minutes ago, ACE said: 60-80 miles range at best is not good enough https://www.caranddriver.com/reviews/a39411899/2022-taiga-nomad-electric-snowmobile-drive/?utm_campaign=socialflowFBCD&utm_medium=social-media&utm_source=facebook&src=socialflowFBCAD&fbclid=IwAR3V4qESUILtDYkofgcTs7xuz7EiMm9OAVhe6mjr242CUmVYKf5D_nKhS2k 60 80 mile range is sufficient if your riding partner is on a Doo... trust me. 1 Quote Link to comment Share on other sites More sharing options...
Rod Posted March 19, 2022 Author Share Posted March 19, 2022 3 minutes ago, Snake said: 60 80 mile range is sufficient if your riding partner is on a Doo... trust me. But then your battery range will be cut in 1/2 again because you have to tow them 1 Quote Link to comment Share on other sites More sharing options...
Snake Posted March 19, 2022 Share Posted March 19, 2022 11 minutes ago, ACE said: But then your battery range will be cut in 1/2 again because you have to tow them 1 Quote Link to comment Share on other sites More sharing options...
Platinum Contributing Member steve from amherst Posted March 19, 2022 Platinum Contributing Member Share Posted March 19, 2022 19 minutes ago, ACE said: But then your battery range will be cut in 1/2 again because you have to tow them Add in circling back looking for them. Quote Link to comment Share on other sites More sharing options...
snoughnut Posted March 19, 2022 Share Posted March 19, 2022 1 hour ago, ACE said: But then your battery range will be cut in 1/2 again because you have to tow them ......and even less if it's below zero. Quote Link to comment Share on other sites More sharing options...
Platinum Contributing Member steve from amherst Posted March 19, 2022 Platinum Contributing Member Share Posted March 19, 2022 the Nomad can be plugged into a standard 120-volt outlet, but a full recharge there requires 13 to 14 hours—which means an overnight charge back at the cabin is possible, though just barely. Taiga claims that the Nomad's motor can deliver a top speed of 60 mph. Taiga claims this setup provides 62 miles of range thanks , but no thanks Quote Link to comment Share on other sites More sharing options...
Rod Posted March 19, 2022 Author Share Posted March 19, 2022 The 180 hp version probably has some zip but it’s probably only able to hit 30 Miles if you use the power Quote Link to comment Share on other sites More sharing options...
Ez ryder Posted March 19, 2022 Share Posted March 19, 2022 Pretty expensive for a from the Cain to the bar and back toy . Prob OK for a yellowstone type tour sled and will most likely be mandatory for them when the next round of liberal dipshits are elected Quote Link to comment Share on other sites More sharing options...
Guest Posted March 19, 2022 Share Posted March 19, 2022 2 hours ago, Ez ryder said: Pretty expensive for a from the Cain to the bar and back toy . Prob OK for a yellowstone type tour sled and will most likely be mandatory for them when the next round of liberal dipshits are elected I was thinking some Liberal run ski resort may buy these to be "more green"??The range would be adequate for workers to use. Quote Link to comment Share on other sites More sharing options...
