needs a sub-forum
  • Replies 104
  • Views 6.2k
  • Magic has been performed, look forward to getting it all back together.  If anyone needs a guy that is meticulous, particular and just does shit right, pm me for his contact info.
  • no hopefully I'll get them back next week and begin the assembly process, start up and break in - hope our snow sticks around...
  • grey area, as the 2008-2011 600 SX & XC are the same chassis as the 2010-2014 Sno Pro 500. good news is, @mnstang & @Fast 440 are here, so that's about 60% of us that used the one particu
So it appears that one of the cylinders is going lean. Keeps frying one of the plugs bu5 the both appear wet one just gets too hot anD looses it’s good spark. Sticking reed valve?
What exactly do you mean by "frying".  Wet and lean don't really go together.
post up some pictures of the plugs..
Also what plugs are you running?
I know my sled isn't the same but I go though plugs if they are not iridium, BR9EIX.
I also run it fat most of the time, probably doesn't help
it's a contradicting statement, wrapped in an enigma.  it's not even plausible to me being "wet and fried".
OP on this issue, either post some pictures... please explain wth you are talking about with more depth or maybe take it to someone more qualified than yourself for a proper diagnosis.  where are you located?
most in this thread and page are experienced with carbs and this chassis, so start skipping the vague bullshit, make sure the timing is correct, you have proper spark and fueling to each cylinder, maybe do a simple compression check and help us help you.
