snatchslayer Posted April 14, 2017 Share Posted April 14, 2017 Went to start the 500 Sportsman today ,got a turn over no fire. Well it started once,and stalled after 30 seconds. I thought it was out of fuel,so I poured in around 5 gallons and turned it to reserve. That's when it started then stalled out. The overflow line is pouring out has too. So I shut fuel off. Thinking float? Quote Link to comment Share on other sites More sharing options...
ckf Posted April 14, 2017 Share Posted April 14, 2017 4 minutes ago, xcr700 said: Went to start the 500 Sportsman today ,got a turn over no fire. Well it started once,and stalled after 30 seconds. I thought it was out of fuel,so I poured in around 5 gallons and turned it to reserve. That's when it started then stalled out. The overflow line is pouring out has too. So I shut fuel off. Thinking float? Sounds like a stuck float to me 1 Quote Link to comment Share on other sites More sharing options...
f7ben Posted April 14, 2017 Share Posted April 14, 2017 I know less about carbs than I do about rocket science but its a stuck float 1 Quote Link to comment Share on other sites More sharing options...
spin_dry Posted April 14, 2017 Share Posted April 14, 2017 float/needle/seat assembly. carb needs a good cleaning and going through. 1 Quote Link to comment Share on other sites More sharing options...
Zambroski Posted April 14, 2017 Share Posted April 14, 2017 I'd guess either float or needle seats (fuel leaking?). Should be easy to check. Pull the carb and crack it open to spray the float and case with carb cleaner real good. Then hit the rest of the carb while you're at it. Check linkage and choke while you are at it. I assume this is the first time you fired it up this year? Quote Link to comment Share on other sites More sharing options...
snatchslayer Posted April 14, 2017 Author Share Posted April 14, 2017 13 minutes ago, Zambroski said: I'd guess either float or needle seats (fuel leaking?). Should be easy to check. Pull the carb and crack it open to spray the float and case with carb cleaner real good. Then hit the rest of the carb while you're at it. Check linkage and choke while you are at it. I assume this is the first time you fired it up this year? Nah. I had it running last month for a good ride. Quote Link to comment Share on other sites More sharing options...
Zambroski Posted April 14, 2017 Share Posted April 14, 2017 1 minute ago, xcr700 said: Nah. I had it running last month for a good ride. Then you fucked it up! Quote Link to comment Share on other sites More sharing options...
snatchslayer Posted April 14, 2017 Author Share Posted April 14, 2017 1 hour ago, Zambroski said: Then you fucked it up! Fucker Quote Link to comment Share on other sites More sharing options...
Zambroski Posted April 14, 2017 Share Posted April 14, 2017 6 minutes ago, xcr700 said: Fucker Quote Link to comment Share on other sites More sharing options...
