throttle body
2 hours ago, polaris7541 said:
Hi all ,Is it a normal maintenance to clean the throttle body bore, if so is it good practice to remove them for cleaning, ie crap sucked into motor, also looking to add a fuel system cleaner to tank, any recommendations to what werks the best
B3C Mechanic in a Bottle..
I've never cleaned a throttle body bore, or had to.
They do make a spray specifically for cleaning them.
There's often an idle air control system with the throttle body and associated air ports.  I would think that would be what would need cleaning, if anything.
I would definitely take it off, you don't want that cleaner going through your engine and causing damage.
yep my thoughts too
