Cross Country 600 Leaking Coolant
snowing
Hi this is probably for Krom.
I have a 2018 Cross Country 600 with a coolant leak and tracked the leak down to the 2" coolant hose AC p/n 0613-214. Something sharp must have penetrated the hose. What a mess to get at. Attached image shows the hose. The gas tank needed to be removed to get at the hose. The problem is that heat exchanger under the seat and the heat exchanger in front of the tunnel which are connected by the hose only have about a 1/4" gap between the pipes connected to the heat exchangers and the hose is butted up tight on both ends. Thus I can't simply slide off the hose and it appears I need to drill out the rivets and completely remove the heat exchanger under the seat.
Krom - do you have any experience replacing this hose?
FYI - I called my local dealer and they had never replaced this hose and didn't know how to replace.
Thanks
