  • Replies 2.3k
  • Views 131.7k
  • Buddy of mine picked up his ZR yesterday … pretty excited for him & getting a chance to swap sleds this season!
1 hour ago, mnstang said:
I dig the green jack stands 💚
I have the green jack to match. But I bought the 4 ton and that thing is heavy dragging around. Harbor china had the 4 ton on a deal a while back so I grabbed one
1 hour ago, ZR6000RR said:
His pops paid for them. Loved the belt drive was the fault of the bearing, instead of his constsnt riding in mud. Fucking retard!
Yep riding in mud 3 feet deep caused the jack shaft bearing to fail and the drive shaft to spin in the bearing. Which non of that is possible. It’s a high quality product that can’t make it more than 60 days with every thing falling apart
Wow it might have been able to lift my old Z1 turbo!
dropped the boat off at storage, brought the sleds home... they both started so we're winning so far.
found four idler wheels total on two sleds going buh-byeoh and am about to start throwing $ to Thomas Sno Sports instead of Country Cat based on this... sounds like the rubber on the cheap Amazon ones don't like to stay attached to the wheels.
https://thomassnosports.com/wheelidle-563-od-x-787id-b-1.html?gad_source=1&gad_campaignid=22181391527&gbraid=0AAAAA-tOM7-uMyH-iVxigROaCXuKZ1Nhp&gclid=CjwKCAjwxrLHBhA2EiwAu9EdM9v37BxKPgoVsahVzkC1lb-VxQwmJvq-FZEvs--1T-sJB8OCKOAjIhoCxQMQAvD_BwE
$34.16ea
https://www.countrycat.com/arctic-cat-3604-807-5-63-inch-idler-wheel-2009-2025-bc-cf-f-m-t-xf-zr?srsltid=AfmBOop4DISGVKGA6FWtcVh6nmUsvAoMhlQo_nN6HhhEEY7YcVJpideG
$54.99ea
https://www.babbittsonline.com/oemparts/a/arc/6015bd5c87a86611b0300984/idler-wheel-assembly
$43.64ea
$34.16ea
$54.99ea
$43.64ea
J & T Products
No image preview
Arctic Cat Firecat sabercat front wheel kit
This J & T front wheel kit will help with wear of the hifax at the front curve.
Or go on Dennis Kirk and order the pdp wheels that fit your sled. They will be the same ones cat used
already gave TSS my $
Got the Lynx off the rack late last night. Turns out that thing needs slides, the ole skool rivet on slides.
Damn.
Damn.
That sound like a 6 pack project at the minimum
I'm not having the Devil's Fire Water right now, or I'd make it a 12 pack minimum.
I'm thinking it'll be easier with the skid out to do that project.
At least the Cheetah fired right on up and idled great. Waiting for that one to spite out the drivers.
put Arctic Cat # 2604-799 into your search engine and be prepared to be shocked... roflcrying
oh, and Stud Boy studs with the plastic backers are absolute fucking junk
I got those for $3 each from AC website before Gregb spread it on FB and prices went way high. I suppose it's my fault for posting it here too
I should have ordered more. My cheap track was good
needed a set for the fohfohty but Dennis Kirk'd a pair. still have a pair of Cat slides in the attic for the five hundo and have vespels on the mod.
that said, quite a significant price increase vs $15-20 a couple years ago.
That is $41 for the pair. They are not a whole lot cheaper on DK for the Garland ones.
Completely read that wrong! $41 a slide is nuts.
I normally pick up cheap slides at Princeton or whatever I go to for swaps. I certainly didn't see any this year at Princeton or Haydays.
Edited by racinfarmer
They are for a165 you fucking fake racing, non farming idiot! Look at what other brands are charging. Christ!
Someone finally took sympathy on you and pulled out the ole Tainternational from the dry beet field?
Thomas has them for your sled for 8 bucks. I texted you a picture
Tariffs working their magic.
Ok, or Cat's ERP system feeding into its PG&A system doing it's thing too.
I don’t know what Cat’s ERP system is? Prices are going up on all kinds of things in my different hobbies. I check my past orders on Amazon before ordering anything and by and large everything has increased since this past spring.
right, I had to do a double take
weird how cat lists the same part # for the slides for a 121" as a 165" eh?
you really are an ignorant fuck... go dig a hole and sit in it
turn those knobs up to 3
but those are for a 137"!!!!!!!! crazy
Happy Cracking Up GIF by MOODMAN
My sawzall broke, but my chain saw will still make long slides short.
https://shop.arcticcat.com/2604-799#/s/ARC//2604-799//1/y
This Side Rail measures at about 53.5" long and will need to be cut to length of snowmobile when being installed.
Jim Carrey Alrighty Then GIF by Ace Ventura
sounds like someone here hasn't changed a pair of slides on his own in over twenty years, probably something so complicated it has to be taken to the world's greatest dealership to be done.
