Mystik oil at crappy tire
steve6
anyone seen this oil?? I went to grab some today for the boat (which is an old pre-mix). I used to just run the gray Fromula1 jug and use it in everything (pre-mix, seadoo oil injection and snowmobile oil injection older sled)
http://www.canadiantire.ca/en/search-results.html?q=mystik%20oil
I was confused as fuck what to buy
http://www.canadiantire.ca/en/pdp/mystik-jt4-premium-plus-outboard-engine-oil-4-l-0281734p.html#srp
Mystik JT4 Premium Plus Outboard Engine Oil, 4-L
  • Mystik JT4 Premium Plus Outboard Engine Oil provides superb protection for high performance, high horsepower, 2-stroke outboard engines
  • Reduces carbon and deposit build-up on engine parts and piston ring sticking
  • For direct injection of pre-mix; mixes readily at low temperatures
http://www.canadiantire.ca/en/pdp/mystik-jt4-all-in-1-outboard-engine-oil-4-l-0281732p.html#srp
Mystik JT4 All-in-1 Outboard Engine Oil, 4-L
  • Mystik JT4 All-in-1 Outboard Engine Oil contains fuel stabilizer, Ethanol fuel treatment and powerful detergents to remove existing carbon deposits from your engine
  • Can be used in multiple 2-cycle engines including marine, recreation, power equipment and lawn and garden equipment
  • Size: 4 L (1 gal)
http://www.canadiantire.ca/en/pdp/mystik-jt4-synthetic-marine-engine-oil-4-l-0281738p.html#srp
Mystik JT4 Synthetic Marine Engine Oil, 4-L
  • Mystik JT4 Synthetic Marine Engine Oil is formulated to meet warranty requirements of Mercury, Yamaha, Evinrude and other leading OEM's
  • Superior rust and corrosion protection in high-performance marine engines under the harshest marine environments
  • Outstanding scuff and wear protection
  • Size: 4 L (1 gal)
http://www.canadiantire.ca/en/pdp/mystik-jt4-synthetic-blend-marine-engine-oil-4-l-0281739p.html#srp
Mystik JT4 Synthetic Blend Marine Engine Oil, 4-L"
Mystik JT4 Synthetic Blend Marine Engine Oil has been formulated to meet the demanding requirements of 4-cycle marine engines requiring NMMA FC-W® oils NMMA FC-W® oils
  • Formulated to meet the warranty requirements of Mercury, Yamaha, Evinrude and other leading OEMS
  • Size: 4 L (1 gal)
http://www.canadiantire.ca/en/pdp/mystik-sea-and-snow-2-cycle-engine-oil-5-l-0281781p.html#srp
Mystik Sea and Snow 2-cycle Engine Oil, 5-L
  • Sea and Snow 2-cycle Engine Oil protects high-performance 2-cycle engines against exhaust port blocking, combustion chamber and piston deposits, ring sticking and wear
  • Mixes readily with fuel for pre-mix type, even at low temperatures
  • Designed for use in high-performance air-cooled or liquid 2-cycle snowmobiles and personal water crafts
  • Available size: 5 L
