1trailmaker Posted February 6, 2018 Share Posted February 6, 2018 3 hours ago, Kev144 said: Foil type collects lint much more than others 2 hours ago, 1trailmaker said: yea it most likely will, dryer vent cleaning should be a regular cleaning task. Sharp 90' turns also collect more lint Lint catcher should be cleaned every time you use the dryer - this give better air flow leaving less chance of lint in the vent tube 40 minutes ago, Puzzleboy said: Obviously a corrugated pipe is more prone to lint buildup, Fail. And I've never found rigid ducts a "hope in hell". Once it's cut to size, just jockey the dryer back into position. Try it when you're not stoned. Might make it a bit easier. right on top of it again I see Thanks Quote Link to comment Share on other sites More sharing options...
1trailmaker Posted February 6, 2018 Share Posted February 6, 2018 41 minutes ago, Sksman said: Thanks 02 Fail. Did your friend have a dryer vent pipe installation company? Quote Link to comment Share on other sites More sharing options...
