Removing brake caliper and rotor on an XP?
  • Please log in to reply
20 replies to this topic
#1 Wolfie Version 8.1
Wolfie Version 8.1
    Woolie
  • USA Contributing Members
  • 34,835 posts
Posted 22 February 2010 - 06:55 PM
This weekend, I stuffed a rock into my tunnel area right below the brake rotor, and pushed it up so its rubbing now. It doesn't look serious, I should be able to pound it back into shape, but I need to remove the rotor and caliper to do so. I can't find any mounting bolts for the caliper :wtf:
#2 Catbox
Catbox
    Member
  • Members
  • PipPip
  • 20,810 posts
Posted 22 February 2010 - 09:51 PM
I seem to remember a pic of you're yammi half up onto a big rock too, these things aren't friggin' jeeps you know!!! :lmao:
#3 Ben
Ben
    I Contribute Nothing To This Site
  • Members
  • PipPip
  • 16,434 posts
Posted 22 February 2010 - 10:01 PM
Hey Wolfie, I had to remove the whole brake assy in order to change my track. There is no bolts holding on the caliper or the rotor. Just remove the circlip and pull the rotor of with caliper attached, once off you can pull the disk out of the rotor. You'll notice a little black cage type thing that protects the caliper if the belt blows, I removed that as well for helping move around the caliper.
#4 Wolfie Version 8.1
Wolfie Version 8.1
    Woolie
  • 34,835 posts
Posted 23 February 2010 - 04:54 PM
Thanks Ben....I have two pairs of circlip pliers, and neither one is big enough to get that bitch off :lol:
#5 Ben
Ben
  • Members
  • PipPip
  • 16,434 posts
Posted 23 February 2010 - 05:23 PM
I just use needle nose plyers, or two nail punches.
#6 s pump
s pump
    Member
  • Members
  • PipPip
  • 3,118 posts
Posted 23 February 2010 - 07:29 PM
How big is it. I have a pretty good set of C clip pliers if you need it.........2 feet in Mts of Vt there saying....
#7 Webba
Webba
    Member
  • Members
  • PipPip
  • 80,679 posts
Posted 24 February 2010 - 10:06 AM
Beter bring some spare riding gear in case someone doesnt bring theirs Gary :fluffy: :bc:
#8 Sugarloaf
Sugarloaf
    Member
  • Members
  • PipPip
  • 5,811 posts
Posted 24 February 2010 - 11:28 AM
Can't help you. My XP was made to ride in snow so I've never had an issue with a rock... that's why they call them snow machines not rock pile machines :dunno: :lmao: :lol:
#9 Webba
Webba
    Member
  • Members
  • PipPip
  • 80,679 posts
Posted 24 February 2010 - 11:35 AM
#10 99mxz600
99mxz600
    Member
  • Members
  • PipPip
  • 2,051 posts
Posted 24 February 2010 - 11:41 AM
:lol: He isn't real bright and sounds like someone else I know on these sites, always asking stupid questions when it comes to working on shit. :snack:
#11 Sludgey
Sludgey
    moto is a stupid nigger
  • CDN Contributing Members
  • 34,940 posts
Posted 27 February 2010 - 01:31 PM
the caliper is bolted to the tunnel behind rotor. you can get at the torx head bolts through the holes in the rotor. you might need to apply a little heat to get the caliper housing off the bearing though.
#12 Ben
Ben
  • Members
  • PipPip
  • 16,434 posts
Posted 28 February 2010 - 03:08 PM
Shit your right! Sorry Wolf, forgot all about the plate that hold the bearing steady.
#13 Wolfie Version 8.1
Wolfie Version 8.1
    Woolie
  • 34,835 posts
Posted 28 February 2010 - 09:12 PM
Yeah, ya mean that plate that I somehow managed to break today, when I went to put it back together? Still like to kick Francois the engineer who designed this thing, right in the nuggets for mounting a brake disc that close and vulnerable to the snow.
#14 Ben
Ben
  • Members
  • PipPip
  • 16,434 posts
Posted 28 February 2010 - 10:10 PM
You broke the plate on the inside of the tunnel? I don't think you have to move that plate to get the caliper off just unbolt it.
#15 Wolfie Version 8.1
Wolfie Version 8.1
    Woolie
  • 34,835 posts
Posted 28 February 2010 - 10:20 PM
well, it got loose, after it was unbolted. It lines up and swivels into place, which aligns and holds it for the caliper torx screws that bolt into it. Given that its described as a "bearing plate", and not a "caliper mounting plate", and given that the bearing essentially pressfits onto the caliper, you have to apply a decent amount of torque to get the bearing to seat into the caliper housing. I cross tightened it, thought I was pretty thorough, but the mf'er somehow got jacked up, bent, and eventually cracked as I torqued it down. Still not happy with that design at all.
#16 Ben
Ben
  • Members
  • PipPip
  • 16,434 posts
Posted 28 February 2010 - 10:26 PM
That's weird? Mine was hard, although I had to pry the place off to get the drive shaft off, the main reason for that plate is too hold the bearing.
#17 Sludgey
Sludgey
  • 34,940 posts
Posted 01 March 2010 - 01:55 PM
i've never actually had a problem with pressing the housing back on the bearing with the bolts. did you have the bearing plate in place properly? there is three tabs that you have to put in place on the tunnel and give the plate a turn. if these arent in place properly i could see that plate breaking quite easily.
#18 grggade
grggade
    Member
  • Members
  • PipPip
  • 1,952 posts
Posted 01 March 2010 - 06:07 PM
Lol I know how you feel Wolfie , I ve got pretty good on the Rev's , but our the XR & Xp are a whole new thing :bh:
#19 Ben
Ben
  • Members
  • PipPip
  • 16,434 posts
Posted 01 March 2010 - 09:10 PM
I love working on the XP.
#20 Sludgey
Sludgey
  • 34,940 posts
Posted 01 March 2010 - 11:08 PM
it's actually not that bad
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
